Best PPT,TDC,EDC values for 65watt cpu
Solved by Chris Pratt,
There are no best values. It's unique to every chip and rig. My "best" values for my 5900X changed from switching power supplies. The one you need to pay attention to is EDC. Find the value that gives you the best performance, while ensuring that PPT and TDC are not limiting you (both less than 100%). Then, adjust PPT to where you're hitting 100% on that and EDC at load. Finally, adjust TDC the same, to where you're hitting 100% on all three.
