Search In
  • More options...
Find results that contain...
Find results in...
Entry level PC for about € 600 based on i3-10100F and 1050 Ti
Go to solution Solved by Dr0idGh0sT,
Because this PC is not going to be used for GPU intensive tasks, integrated graphics in 5600G will be more than enough for everything, While it being much faster PC overall. Much better CPU, Faster RAMs, Better board, More storage. Also, U can get 400W PSU, But I added 650W because it's only 20 euros more and it'll allow adding good graphics card in future if needed, But if this is not going to happen, U can save that 20 euros on PSU.
Anyways, This PC will run everything much faster and better, Because that I3 will botleneck everything... 😄
P.S. CPU comes with good enough cooler.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  (€265.99 @ Amazon Deutschland)
Motherboard: Gigabyte B550M DS3H Micro ATX AM4 Motherboard  (€82.90 @ Amazon Deutschland)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€67.90 @ Amazon Deutschland)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive  (€93.17 @ Amazon Deutschland)
Case: Deepcool MATREXX 30 MicroATX Mini Tower Case  (€35.20 @ Amazon Deutschland)
Power Supply: EVGA BQ 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  (€69.87 @ Amazon Deutschland)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (€5.96 @ Aquatuning)
Total: €626.95
Generated by PCPartPicker 2021-09-27 10:31 CEST+0200
Heya, I'm building an entry level budget PC (~ € 600) for a friend. I would like some advice on the selection of components and balance between CPU and GPU if possible. Also this is a µATX mainboard and case, but I think with the two case fans temperatures shouldn't be a problem. Using a power calculator resulted in about 360 Watts so the PSU should suffice. This PC would be used for office work and low-end games like League of Legends or older games with simple graphics. GPU availability is very limited in my region (Germany) so the best card under € 200 I could find is the GTX 1050 Ti.
Components:
  • CPU: Intel Core i3-10100F -- € 86,90
  • CPU-Fan: be quiet! Pure Rock Slim 2 -- € 24,99
  • Mainboard: GIGABYTE H510M H -- € 74,90
  • RAM: G.Skill DIMM 16 GB DDR4-2666 Kit -- € 56,90
  • SSD: Samsung SSD 980 NVMe M.2 500 GB -- € 53,90
  • GPU: MSI GeForce GTX 1050 Ti 4GT LP -- € 199,90
  • PSU: be quiet! System Power 9 CM 400W -- € 49,99
  • Case: Chieftec CI-02B-OP -- € 54,90
  • Case-Fans: 2x SilentiumPC Zephyr 120 PWM 120x120x25 -- € 4,99
Sum: € 612,36
Total: €626.95
@Dr0idGh0sT Heya, thank you very much for your help. We assembled the PC today according to your recommendations but with a different case instead, so far everything looks very good!
If we wanted to install a graphics card in the next few months, which model would you recommend? For the price we would like to stay under € 200-250 if possible (no problem with used graphics cards from eBay). I was thinking about a Nvidia GeForce GTX 1650 / 1660, but I'm not sure about which cards from AMD are currently good for the price range. Maybe the AMD Radeon RX 560 / 570?
Great! Yeah, case is wasn't too good in my list.
1660 could be great option, 1650 is more budget card and falls far behind 1660.
From AMD, At least RX 590. You can also try to get GTX 1070 or Radeon R9 Fury/Fury X, Maybe even better if possible, Radeon RX Vega 56/ RX 5600XT, But I doubt it'll be possible, At least it's worth trying, Because there is somewhat less demand on AMD cards and u might get lucky.
Thanks again! We will keep our eyes open on some local reselling platforms for the time coming. For now the integrated GPU is enough for most games. If the opportunity arises for a GTX 1660 / 1070, RX 590 some newer AMD cards like the RX 5600 we will upgrade.
Overall I'm really happy with this build, not buying a low-end GPU and instead investing in a much stronger CPU that will last for the next years was definitely the better option. After all it's really hard to get a new GPU for a reasonable price at this time and maybe for the next year as well.
That's good to hear.
Hopefully GPU prices will balance soon enough.
