Search In
  • More options...
Find results that contain...
Find results in...
240hz monitor, freesync premium on or off?
Go to solution Solved by _sirhC_,
19 hours ago, jaslion said:
On of course. You don't get any noticeable input lag/any input lag from it.
Alrighty, thanks for the answer.
Hey guys, I have just bought a 240hz monitor. Its an ALIENWARE 2521HFA and I was wondering if I should have freesync enabled for the least input lag.
I mainly play Valorant and sometimes CSGO. In valorant I can maintain 220-300 fps almost always but from time to time I do dip below 200. So I was wondering if I should have freesync enabled for those time?
Does freesync increase input lag by a noticable amount?If I turn freesync on should I limit my fps in any way?
Thanks for the answers.
13 hours ago, Nacht said:
If had 3 original G9 that had issues but freesync premium pro as well as a G9 Neo that came in doa, and honestly i really wish i had freesync on already, but i have to do with this shitty 1440p 165hz acer panel that only supports gsync with my 6900 XT that i got in may, while i got my first G9 in june or so *sad noises*
Unlucky mate  😄
