Thoughts on my First Gaming PC
Deltatiger
Budget (including currency): 2000 USD (in INR, so around 150K INR)
Country: India / Chennai
Games, programs or workloads that it will be used for:
Building one mainly for Gaming and some programming work (pet projects mostly).
Games:
CSGO
Games like Witcher (cinematic games?)
Battle Field / CoD
Civilization (Anno?)
I just got a Nvidia 3070 TI FE after waiting for couple of months at MSRP (55K INR / 750 USD). So going to build a PC intended for 1440p gaming. I like keeping the settings at high unless I can't really run it.
Upgrading from a laptop with a dead gpu.
Will get the monitor later on (maybe couple of months).
Couple of questions I had,
  • Air cooling vs AIO ? I live in a place that is mostly hot (ambient 34+ in the summer) so unsure of what I should get.
  • 5800x vs 5600x ? I am not sure if I need a 5800x or would it be better if I upgrade the GPU after couple of years?
https://pcpartpicker.com/list/wc8kVc
Thank you for your feedback
I think your list is perfect, I would recommend upscaling the ram to 3600mhz, and if your planning on playing a lot of games, only 512 gigs will run out really fast.
To your questions:
1- A High performative air cooler (like the one you listed), will perform on par or even better than an AIO cooler around that price.
2- I'd choose the 5800X as the 5600X is an awesome cpu but might bottleneck your 3070Ti
Hope this helps!
CPU - AMD Ryzen 5800X - 37300
Cooler - Deepcool Assassin III - 7360
Motherboard - MSI B550 Tomahawk - 17250
RAM - Get Crucial ballistix or G.skill Ripjaws V 3600mhz CL 16, Or at least 3200mhz CL 16 ~10000
Drive - 1TB EXCERIA NVME SSD KIOXIA - 9700
Case - Fractal Design Meshify C - 5500
PSU - NZXT C750 - 10700
Fans - Arctic P12 - 3X - 2400
Total = ~120000
Here you go.
To your questions:
Hope this helps!
Thank you for the feedback. I will get faster RAM. I was planning on getting more storage as a 7200 RPM HDD. Will see if I can get a better SSD for now.
Total = ~120000
Here you go.
Thank you so much for the IN links. I will take a look at and adopt whatever is possible.
