SpaceDesk Review
Botric
Whats is the SpaceDesk,
This is a piece of software where use can use a tablet laptop or any HTML5 enabled device as a secondy screen.
The software is free and works with IOS and andriod and any browser that allows HTML 5, I did knotice firefox has some issues with memory issues,
I have used on some underpowered tablests and also the latest IPad air 2020, as the tables are touch screen they can be used as a touch screen monitor,
The setup is easy and broadcasts to find yout host machine so no manual entering of ip addresses is needed, for the lag there is som,e its not something you can game from but if you need a secondy display this works well
