Razer Blade 14: 97C Average Temp ok?
Solved by CommanderAlex,
Temps are to be expected due to the form factor and amount of heat these high performance components will put out. You can always try a laptop cooling pad to improve airflow if there is ventilation underneath the laptop (holes or grille underneath).
Perhaps you can limit FPS by using V-sync so that the CPU and GPU are not running at their max frequencies and to reduce heat.
