Corsair HS80 vs HS70 Pro wireless
Dobby_is_free
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
8 hours ago, Tigerleon said:
If you need a mic on your headphones and they need to be wireless. The cloud 2 wireless are going to be much better.
I actually bought and returned 2 pairs a cloud II wireless. Both had a static/white noise in the background and one I had problems with the mic. Any other suggestions?
Maybe Cloud Flight or Flight S
AKG P420 Mic
Other peripherals
I've heard that the cloud flight S has the same issues, are all Corsair headsets bad? Should I really be looking at wired headsets? Wires are just kinda annoying for me, easy to get tangled in
They really aren't annoying. It definitely depends on the cable and your habits. A cheap really good headset that has studio sound are the MH752's from Cooler Master. Those are one of the best even up headphones priced from 150 to 200 dollars I'd say. Lightweight, great sound for the price, the mic is really good for a headset mic, really good build quality etc. Just a solid pair of headphones. Wired is superior in terms of sound, reliability etc. Wireless gaming headsets just aren't comparable.
AKG P420 Mic
Other peripherals
I there a more premium headset you would recommend around $150?
There is no such thing really as premium in the gaming headset world. You want to look at the right ones. Not just because they are more expensive. The MH752's are reskinned studio headphones but with a mic. You won't get much better sound or build quality around 100-150$. Then you have to move up to maybe 500-1000$ headphones.
AKG P420 Mic
Other peripherals
Thanks for the help man, I'm gonna try one of the Corsair headsets because I've used their products before and like them but if they end up being shit I'll try the MH752 🙂
