Search In
  • More options...
Find results that contain...
Find results in...
Keyboard LED keeps resetting itself
Go to solution Solved by TukangUsapEmenq,
I'm well aware that I shouldn't post on nearly a month old of topic but....
It's practically solved. Turns out the software itself was buggy and updating it solved the problem.
In a nutshell, got a budget-mech keyboard of VortexSeries VX7 Pro. The LED kept getting turned off after my PC turn-off or restart, and I have to set the lights on over and over again on the software every I boot it up.
Screenshot below, I tagged the settings that I have to tick every time I boot.
Software bug, BIOS settings, or what? It's weird as I have no issue like this on another laptop/PC, and I don't have to do that on the other ones, just here on my daily driver.
Thanks in advance.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
Intel Xeon E3-1225 v2 3.2 GHz 4C/4T CPU
ASRock B75M Motherboard
Team Group 2x4 GB DDR3 1600 MHz RAM
480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD
be quiet! System Power 9 500W PSU
Cooler Master T20 CPU Cooler
Samsung S19D300 + LG L177WSB Monitors
Fantech X6 Knight Mouse
VortexSeries VX7 Pro Keyboard
Acer Aspire 4253, runs as NAS 24/7
AMD E-350 1.6 GHz 2C/2T CPU
3 GB DDR3 1066 MHz RAM
1 TB HDD for whole family movie pleasure
Xiaomi Redmi Note 8
4GB RAM, 64GB Internal Storage
64GB SanDisk Ultra (80MB/s Read) External Storage
Resurrection Remix Custom ROM
Audio
Some random home-theater speakers I took freely from someplace and big-ass bass with old computer speaker amplifier. It sounds good af tho.
dbE DJ100 Headphone
Rock Space Obsidian Earphone
(all hail kere hore audio hahah)
  Hide contents
Thanks in advance.
Probably because it doesn't have a storage chip to save the settings to.
On your other devices doesn't it reset after you turn them off?
A PC Enthusiast since 2011
AMD Ryzen 5 2600@3.9GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R15: 1382cb | Unigine Superposition 1080p Extreme: 3439
Seems it does have it, it saves the last settings I put on it while using it on the PC that don't have the software.
It doesn't. That's why it's weird.
Diccbudd PC
Xiaomi Redmi Note 8
Audio
dbE DJ100 Headphone
Does it work if you set it up on one machine and have the software uninstalled on the daily driver?
  • 4 weeks later...
Diccbudd PC
Xiaomi Redmi Note 8
Audio
dbE DJ100 Headphone
