4000D Airflow Fan Setup
Skel71
have a new 4000D Airflow case and looking to get recommendations on case fan setups. I had planned to get additional fans after the initial purchase and i could look at the case. Using the system for virtualization, AI development workloads and gaming. Currently running with only the 2 default case fans and side panel removed for cooling.
System build:
i9-11900K Air cooler used
RTX-3090 FTW3
Asus ROG Strix Z590E
Questions
1. 2 x 140 fans on the front vs 3 X 120?
2. Top Fan(s) are they worth it?
   2a.  If yes same as question 1
   2b.  Alignment of Fans on top all in take or all exhaust or front 1or 2 intake and rear exhaust?
3. Recommended brand? I don't care about RGB
What do people have and what works well?
System build:
RTX-3090 FTW3
Questions
are you using an aio for the cpu or tower cooler? if aio i put it on the top as exhaust and can have the back fan exhaust and front intake .
if you have a tower cooler i would not add any fans to the top only the back exhaust and front intake. if gpu temps still to hi passably add a fan to the back top as exhaust.
3x 120mm push more air but 2x 140mm should be quieter so up to you i guess.
as for what fans well there's a few just depends on how much you want to spend i guess.
cheap artic pwm p12/p14 fans 5 pack
i like the gentle typhoons pwm (i payed like $20-$25can for mine) there alot of diffret versions of it thow...
expensive noctua
expensive phanteks t30
other fans
Thermaltake ToughFan 12 2pack
Thermaltake TOUGHFAN 14 Black PWM 2pack
Scythe WS-120
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
Thank you for the input
I have a tower cooler for the CPU.
I will also look into the gentle typhoons have not looked at those. I also like the idea of skipping the top fan on first go around and then determine if it is needed.
