4k smart TV for gaming
vladonizer
I am wanting to make a PC gaming setup in my living room with a big 4k TV. I was hoping a 65", decent response time, and 60 fps. I'm not sure if this exists(I know nothing about TVs) I would like to know yalls opinion on what/which TV or if you have better recommendations for what I want to do
Well, you didn't list a budget so this is easy. LG CX 65" OLED. Hands down. $2000.
Big brother to the extremely popular 48" CX OLED for PC gaming. 120Hz, Gsync, HDMI 2.1.
Well I don't really have a budget, so I'll definitely put that one on my list to look at.
I don't want to spend more then I have to, but I'd I decide it's worth the extra $ I will
Go for Vizios smart tv if you are on a budget
I have an ASUS G14 2021 with Manjaro KDE and I am a professional Linux NoOB and also pretty bad at General Computing.
ALSO I DON'T EDIT MY POSTS* NOWADAYS SO NO NEED TO REFRESH BEFORE REPLYING *unless I edit my post
Its an OLED, nothing else is really going to compare.
Why not 120hz.
The 3090 has HDMI 2.1 so 4k 120hz.
All my TVs are 4k 120hz, Ge-sync compatible and there are 65" versions of them.
For gaming and streaming the LG BX model is fine. If you are into 4K Blu-Ray the CX may be better. I can't tell the difference in the show room.
I use a Nanocell 85 as well and it is a better monitor than it is a TV and now it is the NanoCell 90 in 2021.
I use 2 for gaming but if I had young kids I would give them a pass. They may not remember to switch it off.
I burnt one in doing what we are doing now. That is why I bought the Nanocell.
I am not much of an adult.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
What about Neo QLED
1 hour ago, jones177 said:
Why not 120hz.
Will I realistically feel a difference between oled and qled as far as response time?
I honestly didn't know that there was a 120hz tv. Right now I can't run it any higher then 60, but I'll probably upgrade my PC next year
RTINGS.com should have done tests to check for Input lag, response time and refresh rate. I would look in to their data first.
Even with older GPUs you can still do 1440p and 1080p. It looks better than my LG 32" 1440p monitor.
Use https://www.rtings.com/ for response times.
Response time as in pixel response or inputlag? Inputlag has nothing to do with LCD and OLED.
Pixel response is a different story and yes, OLED is much faster than any LCD.
QLED is nothing but marketing bullshit by Scamsung, don't fall in their trap. I'm not sure about the CX in your country but there is the LG C1 65" too. The CX and C1 are very popular amongst gamers. I was about to get the 48C1 but I'm holding off till 42" OLED.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
