Turn table Cartridge help
Hamface55
Hello,
I recently just picked up an old pioneer PL-450 from a thrift store. Great condition. The only thing needing replaced is the cartridge. I am not sure which one to buy. Not looking for anything too expensive. But what would you guys recommend? The way the pre-existing cartridge attaches is 4 metal prongs in the shape of a square. I ordered one online, but unfortunately didn't do my part of research, and the connection doesn't work. Anything you guys can recommend?
Thanks!
https://www.amazon.com/REPLACEMENT-NEEDLE-Pioneer-PN-250T-PL-450/dp/B08F7G34M2
5 seconds Google...
This is a belt drive ...? I hope it wasn't expensive,  on the other hand if it works, and is needed just for playing back records it doesn't matter much i guess.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
