Looking for a compatible m.2 wifi card
Szeth
I have a b450f gaming 2 motherboard, with an amd cpu. I am looking for a m.2 wifi card, ideally wifi 6 and bluetooth, but I'm not sure how to find something that is good and compatible. Looking for any recommendations that you guys have.
Also, is there a difference between m.2 and PCIe for wifi cards?
M.2 is the physical connector, PCIe is the protocol used.
20 minutes ago, Szeth said:
Thanks for the response! So would any ax200 2230 card work, because there seem to be a lot of different options on amazon.
Looks like it. If you're going to get one, you might as well just get the official Intel kit. I guess the only downside is the PCI bracket antennas and not an external antenna you can move around.
