EVGA GTX 980 Ti cooler
realCessnaBroon
Does anyone have any idea where I could find a stock shroud and cooler for this GPU? I just bought one on eBay, but it doesn't have either.
It's an EVGA GTX 980Ti with model number 06G-P4-4990-KR.
Thanks very much.
keep an eye on websites like ebay or craigslist. someone might sell a broken 980ti from which you can salvage the cooler
there might be aftermarket ones maybe on websites like aliexpress, but i have no experience with that
So are coolers/shrouds from different manufacturers usable? Like an MSI 980Ti for parts - if I used it's shroud. Or an EVGA with slightly different model - like an EVGA 980 for parts, or 980TI superclocked instead of gaming?
Usually they use same cooler for few cards (from same manufacturer of course) so you may be lucky, best what you can do is to find some coolers and later on compare the pcb of this cards, if they same than the cooler should fit as well.
So you missing heatsink as well yes? You have just the pcb?
   @Whiro tag or quote will do the trick
i5 3570K @ 4.7Ghz  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  (mesh panel) |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop
                EKWB EK-XRES 140 Revo D5 RGB PWM
                EKWB EK Supremacy Evo , naked die
                EKWB EK Thermosphere
                EKWB EK CoolStream PE 360
                EKWB EK Coolstream SE 120
                EKWB EK Vardar 120s  x6
                EKWB EK STC Classic 10/16  x10
                EKWB EK DuraClear Tubing 16/10
                EKWB EK CryoFuel Acid Green
Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
So I've got the PCB and the heatsink. I installed the GPU, but it gave me solid white CPU ez debug, so I removed it again, and it's still there. My pc worked before, and I've been using it for two weeks no without a GPU. Any ideas?
If you have pcb and the heatsink than you can always ghetto your cooling by strapping some normal case fans to it, I’ve done it before and it’s working really well.
Did you connect all cables properly to the gpu? You didn’t knocked any other cables or cooler for cpu? Try resetting the bios to default first
                                          WHIRO
All cables were connected correctly, and I couldn't boot to bios because no graphics from igpu or dgpu. Monitor detects no input from DP.
