Search In
  • More options...
Find results that contain...
Find results in...
I'm not sure how to use MiniTool Partition Wizard
Hey guys, so I want to migrate my HHD to the new SSD. I want to migrate from disk2 to disk 1, however it seems to be that it is migrating from disk3 to disk1 as the partition of  disk1 doesn't look like like disk2 (like shown in the picture). I'm not sure of this so can someone please clarify it for me. Then if it is migrating from disk3, how do I change it back to migrate from disk2. Thank you so much for helping.
So what Windows reports in Disk Management and what MiniTool Partition Wizard reports, may not be the same. Easiest way is to select the partitions/drives based on what the content is. Check Disk Management and make note of what partitions are on which drive. Then in MiniTool select the source drive that has the same layout as the drive you want to clone.
Since you are doing this in a PC, the PC's drive/Windows installation will likely be drive 0 or 1. You don't want that one.
You want to make sure you are not cloning the PC Windows to the new drive, but rather the old laptop drive to the new laptop drive.
The new blank (destination drive) should not have any partitions or data on it and should show up as one big drive with unallocated space.
23+ yrs IT experience
MAIN SYSTEM
Operating System
Windows 10 Pro x64 21H1
Case
Antec Three Hundred Two Gaming
CPU
AMD Ryzen 9 3900X 3.8GHz 12-Core 24-Thread
Motherboard
Asus ROG Strix X570-E Gaming
RAM
G.Skill Trident Z RGB Series 32GB
(2 x 16GB) DDR4 3200 (PC4-25600)
Graphics Card
Asus Nvidia Geforce RTX 2060 Overclocked (Factory) 6GB GDDR6
Dual-Fan EVO Edition
Storage
2 × Samsung 970 EVO Plus Nvme (M.2 2280) SSD 1TB
2 × Samsung 860 QVO SATA III 6.0Gb/s SSD 1TB (RAID1 Array 1)
2 × Hitachi UltraStar HDS721010CLA330 7200RPM SATA III 3.0Gb/s 1TB (RAID1 Array 2)
PSU
Thermaltake Toughpower GF1 850W 80+ Gold
Optical Drive
LG WH16NS40 Super Multi Blue Internal SATA 16x Blu-ray Disc/DVD/CD Rewriter
Displays
HP w2408 widescreen 16:10 1920x1200 @60Hz
HP w2207 widescreen 16:10 1680x1050 @60Hz
Keyboard/Mouse
Logitech MK200 Wired Keyboard/Mouse Combo Kit
Also, if you know the make and model of the drive, you can look at the drive properties to figure out which drive is which based on Manufacturer/model
I would cancel out of that screen you are in on your screenshot and check and double check which drive is which before proceeding.
You select the source disk you want by clicking on it in MiniTool to highlight it.
https://www.partitionwizard.com/clone-disk/clone-a-hard-drive.html
MAIN SYSTEM
Operating System
Case
CPU
Motherboard
RAM
Graphics Card
Storage
PSU
Optical Drive
Displays
Keyboard/Mouse
Yes, I do know the model name of each drive. Thank you 🙂
Newegg
