First build for AI and Gaming advice (aka Help out a locked down Aussie!)
Solved by adarw,
what do you already have we need a list, not just
10 minutes ago, mzfit said:I already have a couple of ya know Intel i7 16gb machines ssd machines, so dull, so I'd like this to be a little different.
10 minutes ago, mzfit said:be upgradable, so maybe a futureproofed motherboard and other bits I can upgrade as I get richer and braver
if you want upgradable i wont suggest buying now, as this is the end for new ddr4 stuff. no new amd gens are going to be compatible with the current gen mobos.
