SSD speed flying to the roof ? NVMe not worth it anymore ?
Solved by Hairless Monkey Boy,
1 minute ago, DesertCamel said:Is it safe ? would damage my RAMs if used for a long period ? or it's totally fine ?
It has no possibility to damage your RAM.
But there is a chance that if you lose power, any data in the cache that has yet to be written to disk may be lost. It's a low risk, but if you have important files, or frequent power loss you could consider getting a UPS or turning off the RAM cache.
