watercooling Flow Direction? Inlet/Outlet? Where do I begin?
Solved by tikker,
1 hour ago, SamtheMan101 said:
Looks fine. The only reason inlet/outlet matters is that internally the blocks can have machining/routing specifically optimised for a certain direction, so treat ports marked "IN" as inlets and those marked "OUT" as outlets and you'll be fine.
