Dual monitor, Separate audio help
Cmelton86
I'm running windows 10,  the cables out of a 2080, hdmi cable to a lg tv, display port to an acer monitor.   Is there a way to have the audio for monitor one to play through monitor ones speakers, while the audio from monitor two plays through monitor twos speakers.  Pretty much, I want to watch Netflix, youtube, dvd, or blu ray on my tv, streamed from my computer, while playing whatever on my computer and have the audio come from the appropriate place
Open up the Windows settings, go to System > Sound > scroll down to "Advanced sound options" and click on "App volume and device preferences". From there you can choose separate output devices for different applications.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
I've been doing that.  I was curious if there was a way to have the audio for HDMI 1 to play on that monitor while the audio for DisplayPort 1 plays on that monitor automatically.
