Search In
  • More options...
Find results that contain...
Find results in...
Any possibilities of changing Cooler Master T20 fan?
Go to solution Solved by TukangUsapEmenq,
6 minutes ago, AbydosOne said:
Which fan header on the board is it plugged into?
See page 60 in the manual for info on fan settings in BIOS...
Actually, tried both CPU header and Chassis one (after I mistakenly to put it on chassis fan header). No luck. And yes, I tried all of what I thought to control the fan. It doesn't support DC control unfortunately.
I guess @tkitch solution's the way to go. Either the cheapo ID Cooling 9215 or twice the price with the Arctic's.
Thanks for the help guys.
Here's the cooler.
This cooler's actually a good one for my use (rather than getting stock cooler, or anything 'out-of-the-ordinary-of-CPU-cooler-producers' (heck, just lots of RGB), Hyper 212's way overkill, and Noctua's way above budget), even ramming my E3-1225 v2 + HD4000 (no GPU) with Dota 2 60 fps and it still at 50-55 degrees, with NT-H1.
But the only problem is I didn't realize it's non-PWM fan. So, constant 1900 RPM all the time. Kind of noisy tbh despite it said 'quiet'. Perhaps in any chance I would change it to a PWM fan so at least to reduce the noise when it's idling (it runs 42 on idle).
I haven't find anything useful for possibilities to change the fan. Is there any? Even as far as getting custom 3D printed bracket and put one 8 cm or 9 cm fan on it? I love how Noctua's just using metal holder to hold the fans.
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
Intel Xeon E3-1225 v2
ASRock B75M
Team Group 2x4 GB DDR3 1600 MHz
480 GB Pioneer APS-SL3 SATA SSD
be quiet! System Power 9 500W
Cooler Master T20
Samsung S19D300
Fantech X7 Knight
VortexSeries VX7 Pro
Xiaomi Redmi Note 8
4GB RAM, 64GB Internal Storage
64GB SanDisk Ultra (80MB/s Read) External Storage
Resurrection Remix Custom ROM
Aukey Turbo Charger PA-U28 QC2.0 + Aukey CB-CD4 PVC Type-C Cable
Audio
Some random home-theater speakers I took freely from someplace and big-ass bass with old computer speaker amplifier. It sounds good af tho.
dbE DJ100 Headphone
Rock Space Obsidian Earphone
(all hail kere hore audio hahah)
It should work with a 92mm fan.
Arctic makes PWM 92mm fans that work pretty well.
(I don't know what your motherboard is but...) Make sure your fan control is set to "DC" instead of "PWM" if you have the option. The fan speed can still be controlled by varying the voltage on the header, and almost all motherboards should support that along with PWM.
Main System (Byarlant): Ryzen 5 1600X | Asus B350-F Strix | Corsair H80i V2 | 16GB G.Skill DDR4 3200MHz CAS-14 | XFX RX 5600 XT THICC II | Samsung 960 PRO 512GB / Samsung 970 EVO 500GB / Seagate 7200RPM 3TB / WD White 7200RPM 8TB | Corsair CX650M | Mellanox ConnectX-2 10G NIC | Anidees AI-07BW Case | Dell U3415W Monitor | Microsoft Modern Keyboard
TrueNAS Server (Veda): Core i3-4170 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 1x Samsung PM961 128GB SSD / 1x Kingston 16GB SSD | Corsair CX430M | Mellanox ConnectX-2 10G NIC | LSI 9207-8i LBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta): Core i7-2600 | Asus H77M-PRO | Stock Cooler | 8GB No-name DDR3 | EVGA GTX750Ti SC | Sandisk UltraII SSD 64GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Syba USB3.1 Gen 2 Card | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | (all-around awesome machine)
Laptop (Rozen-ZuluSony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | (lived a good life, retired with honor)
Tablet (---): Samsung Galaxy Tab A 8" (crosses fingers)
Tablet (ReGZ)Asus T102HA (BIOS clock doesn't tick, loses time when sleep/off) (I kill tablets with disturbing regularity)
Tablet (Unicorn)Surface Pro 2 (battery will reset total capacity to current charge, leading Windows to think it's always 100% charged until it dies)
Tablet (Loto)Dell Venue 8 Pro (screen discoloration issues, wouldn't update to Windows 10)
Tablet: iPad 2 16GB (WiFi died, basically useless after that)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case
Camera: Sony ɑ7II (w/ Meike Grip) | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance SDXC cards
ASRock B75M, can't find the option yet unfortunately.
Edit: managed to get the motherboard latest BIOS update, still the same.
Noted.
Diccbudd PC
ASRock B75M
Cooler Master T20
Samsung S19D300
Fantech X7 Knight
Xiaomi Redmi Note 8
Audio
dbE DJ100 Headphone
Diccbudd PC
ASRock B75M
Cooler Master T20
Samsung S19D300
Fantech X7 Knight
Xiaomi Redmi Note 8
Audio
dbE DJ100 Headphone
If noise bothers you, the Arctic F9 PWM gets 44cfm at 1800 rpm, vs the ID Cooling getting 44 cfm at 2500RPM
The Arctic will be waaaay quieter in operation
Noted, will be on my consideration then. Thanks!
Diccbudd PC
ASRock B75M
Cooler Master T20
Samsung S19D300
Fantech X7 Knight
Xiaomi Redmi Note 8
Audio
dbE DJ100 Headphone
Have you tried using software like FanControl?
Tried it, still no luck. Seems it needs PWM to work.
Diccbudd PC
ASRock B75M
Cooler Master T20
Samsung S19D300
Fantech X7 Knight
Xiaomi Redmi Note 8
Audio
dbE DJ100 Headphone
