Search In
  • More options...
Find results that contain...
Find results in...
can i connect 2.5inch usb hard disk drive to my phone?
As title reads, is this possible? (using a female to female usb and plugging it into the charging cable didnt work btw lol. thought it was at least worth a try. Im tempted to quicktime order a usb OTG cable of amazon will this work???)
If not, is it possible with a powered usb hub?
If not :cry:
In theory, no.  Because that port is not "expecting" a mass storage device.
I'm very generous with the likes I give out on here; you should be, too.
I never believed in orthopedic inserts, but then I got a pair.  Now, I stand corrected.
My friend gave me his Epi-pen as he was dying.  It seemed very important to him that I have it.
Why do cows wear bells?
Because their horns don't work.
What phone do you have? It should work if your phone has USB-C, and if not all you'll need is a USB-OTG adapter.
Why not? Mass storage devices are absolutely supported on Android devices. Heck, you can even use floppy drives with Android.
Phobos (Primary Desktop)
AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 4GB XFX AMD Radeon RX 570, 960GB Crucial M500, 1TB WD Blue SN550, 2TB Seagate BarraCuda, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro for Workstations
York (NAS/Plex Server)
Intel Core i7-2600K, 16GB 1600MHz DDR3, ASUS P8Z68-V, 1GB PNY Nvidia GeForce GTX 550 Ti, 240GB Kingston V300, 2x3TB HDD, 3x2TB HDD, 750W Dell PSU, Dell XPS 630i case, Windows Server 2019
Yet to be named (Secondary Desktop)
Intel Core i7-2600, 24GB 1600MHz DDR3, ASUS P8Z68-V, 2GB Nvidia GeForce GTX 680, 1TB Samsung 860 EVO, 700W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
Mid 2011 27" iMac (General Purpose Desktop)
Intel Core i5-2400, 16GB 1066MHz DDR3, Apple Z68 Logic Board, 1GB AMD Radeon HD 6970M, 500GB Crucial MX500, 1TB Seagate BarraCuda, macOS High Sierra
It needs power?
5 minutes ago, Robchil said:
It needs power?
A lot of phones are capable of powering a 2.5" hard drive without the need for external power. If that's not possible then a powered USB hub can be used.
... i actually never tried that...  on androids i've only used flash drives with micro-usb or usb-c connector
