Search In
  • More options...
Find results that contain...
Find results in...
would a sound card fix my audio input issues?
Riley 118b
 Share
so essentially my case's audio pin does not match the one on my motherboard and i have tried two different external audio connectors a audio jack to usb and a bluetooth adapter.
if i chucked a sound card into my motherboard would that fix my issues?
also the problem is that the mic does not input (and its not the headset)
thanks in advance
3 minutes ago, tkitch said:
what case and what motherboard?
asus z170 ar
Thermaltake Versa J25 RGB Tempered Glass Mid-Tower ATX Case
Does your audio connector look like this?
How do I connect the HD AUDIO connector into the F_AUDIO header, as it is  an odd shape: techsupport
That's a standard connector, and on that motherboard it goes here:
If your case has a different connector?  Then nothing will fit it, but that would be very odd.
i did check this out before and it does not fit.
It 100% does, unless what you mean is that the cable isn't long enough to reach.
Friends don't let friends use Userbenchmark. Ban the term "bottleneck." Corps aren't your friends. If the PC does what you need it to do well enough, it's good enough. Don't build the "best" system, build the system that makes you happy.
Well, there are 2 options:
1) Your connector is different.  If that's the case *nothing* you buy will fit, as front panel audio is a standard outside of OEMs like HP / Dell / Lenovo.
2) You're doing something wrong.
Can you post a picture of the FP Audio connector from your case?
There are two types of connectors AC97 and HD audio but the wrong one will still fit. If you look at this image there is a pin that is blanked out, if you're putting it in upside down it won't fit.
Also check for bent pins.
SilverStone SST-FP35B Premium 3.5" USB 2.0 Card Reader | eBay
 Share
