Search In
  • More options...
Find results that contain...
Find results in...
beep and flashing red led
my aorus x570 mini had a loud short beep while using my pc, and a red flashy light started. The beep happened again a few minutes later.
Turned off my pc, checked, nothing seems broken or falsely connected. Red light is still on. Couldn't find anything in the manual.
Does anyone know what happened?
Not finding anything in the manual is odd. This “red flashy light”.. knowing what is blinking is likely important.
seems to be a warning led, It was never on before and is quite bright
But which one is it?  It’s sounding like you have a light code and beep code debug system.
 Share
