CPU temps higher then they should on custom loop
Solved by XVB,
21 hours ago, Chris Pratt said:No? I mean it shouldn't. 70C is nothing. Zen 3 should be able to hit at least 95C before it even throttles. You'd need to exceed like 100-105C before it will outright shutdown to save itself.
just to let you know, it turns out, there is a problem with the ram, but not the ram sticks them selves, the bios just does not play nice with 64gb of ram. for some reason even though the mobo suports it. but at least my system is now runing stable on 32gb of ram. thqs for the help
