new pc New pc build ! need help with cpu issue
Solved by Middcore,
4 minutes ago, damefr said:the i5 9500 says it has a maximum of 4.4 gz how would i unlock that or maximize it.
4.4ghz is the maximum turbo frequency for a single core, which the CPU will boost to on its own, depending on workload. In reality the only time you're likely to actually see any single core hit 4.4ghz would be in a benchmark like the single-thread portion of Cinebench.
Again, the 9500 is not an unlocked CPU, and you aren't going to have the ability to change the single-core or all-core turbo frequencies.
