Need recommendations for CPU Cooler fans!
MistahHaskins
I recently bought the Cooler Master Hyper 212 BE Cooler, and my temps are a little bit better however with the push/pull order, it would be optimal for it.
What fans can I use (Has to be 120mm fans) and which ones can I use that can be attatcehd to a Y-Cable for my CPU Cooler Fan Header on my mobo!
Gaming Rig:
CPU: Ryzen 5 5600x  | CPU Cooler: Cooler Master Hyper 212 BE  |  GPU: ZOTAC GeForce RTX 3060 Twin Edge OC  | RAM: Corsair Vengeance LPX 32GB DDR4 3200mhz  |  Motherboard: Gigabyte B450M DS3H V2  |  Storage:  WD Blue SN550 1TB NVMe M.2 SSD  |  Case:  Corsair 4000D Airflow  |  Power Supply: Corsair CX650w Bronze Series
Also forgot to mention it comes with the Silencio FP120 Fan with brackets that attach to the inside of the fan, like majority of the big Heatsinked air coolers! If I need too I can switch that out for better fans if any are better!
Gaming Rig:
Static pressure fans, those would generally be the best on a CPU cooler, radiators, near mesh panels.
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1.TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
Have any ones in mind that are 120mm and are 4-pin? Inside the box has the CPU Fan Header to two 4-pin Fan connectors
Gaming Rig:
Well, I am a big fan of these Noctua NF-F12 PWM chromax.black.swap
PC Setup:
Crucial MX500 2TB
Crucial MX300 1.TB
Corsair HX1200i
Peripherals:
Corsair SP2500
Racing SIM Setup:
Simagic Alpha Mini
CSL Elite Pedals V2
Logitech K400 Plus
ordered 2 of them bad boys! Hopefully they will do my Cooler justice!
Gaming Rig:
Very nice! 🙂
PC Setup:
Crucial MX500 2TB
Crucial MX300 1.TB
Corsair HX1200i
Peripherals:
Corsair SP2500
Racing SIM Setup:
Simagic Alpha Mini
CSL Elite Pedals V2
Logitech K400 Plus
