Is there a standalone vr headset for pc?
Solved by Torreip,
For most VR headset you will at least need some sort of capture station but if you have a high budget you can take a valve index where you can buy the headset and the capture station without the controller. if you are not against second hand you could also get an used headset complete kit for a lower price or even if you don't hate Facebook collecting your data go for a quest 2 who is connectable to your computer. for every option above the price range from 300$ to 900$.
PS : everything is on my best knowledge it may be another way
