Search In
  • More options...
Find results that contain...
Find results in...
Vertical GPU mount in Corsair Carbide 275R
 Share
Go to solution Solved by glenalz81,
Kits like this come with all the mounting hardware needed.
https://www.amazon.co.uk/s?k=vertical+gpu+mount+kit&ref=nb_sb_noss
Hello everyone! Well, the title says everything. I would like to vertically mount a MSI RTX 3060ti Gaming X in my Corsair Carbide 275R case with this EZDIY-FAB cable riser (https://www.amazon.it/dp/B08SJ1CS8S). The case already has 2 vertical slots for the GPU I/O shield, but this cable riser that I've seen also includes two screws to screw the riser itself into the bottom shroud of the case, just above the PSU, to increase stability. I saw that in other Corsair cases there are the two slots to screw the cable extension in, but in the Carbide 275R there are not. The question is, will the GPU be stable even without the screws? And I'm also wondering if the airflow will be a problem, since there will be only 1,5cm of space between the GPU fans and the glass panel. If so, I think that it would be better to buy a vertical mount that replaces the horizontal ones next to the motherboard, since I don't use any other PCIe card. What do you think?
P.S. I'm aware that I would need to change the PCIe from AUTO to 3.0 into the BIOS settings.
My PCAugust 14, 2021
CPU Ryzen 5 5600x  4.0 GHz
CPU Cooler Noctua NH-L9a-AM4 cromax.black
MBD MSI MPG B550 Gaming Plus
RAM Corsair Vengeance RGB Pro 2x4GB ‒ 3200MHz
GPU MSI GeForce RTX 3060ti Gaming X 8GB
SSD Crucial P5 NVMe M.2 500GB
HDD Seagate Barracuda Compute 2TB
PSU Corsair RMx 750W 80+ Gold
Case Corsair Carbide 275R
Fans Corsair 3xLL120 RGB with Lightning Node Pro
Peripherals
Monitor MSI Optix G271 27" 1080p ‒ 144Hz 1ms
Keyboard Razer Ornata Chroma
Mouse Razer Deathadder Elite
Headset Razer Kraken
Controller Nintendo Switch Pro Controller
Yes, that's what I thought! Thank you.
Peripherals
 Share
