Search In
  • More options...
Find results that contain...
Find results in...
Need help with selecting out parts
I've been talking to a bunch of system integrators over the past few weeks and came up with a few options for a pc:
i7 10700f + 3070 for 1900 USD
5800x + 3060 for 1850k USD
Been looking at pc parts and prices for a long time now and would appreciate a fresh pair of eyes advising me on which is better. I want to game, use blender, premiere and after effects.
For Blender, go with 5800x. Cuz this way if you ever have the need to, you can upgrade to the 5950x or the upcoming zen 3+ chip (the one with 3d cache). If you play games a lot more and really want the frames... then the 3070 is better.
Also, avoid Dell.
  • CPU
    i3-6100
  • Motherboard
    Gigabyte H110m ds2
  • RAM
    16gb 2400MHz Corsair Vengence
  • GPU
    1660 super
  • Storage
    500GB 860 EVO & 1TB seagate hdd
  • PSU
    Corsair CX750
  • Audio
    Superlux HD660 Reference Closed Back Headphones
  • Operating System
    Windows 10 (1907)
If gaming is your first priority, I would go for a new gen CPU (AMD Ryzen 5 5600 or Intel Core i5 11600) and a RTX 3070,
Because a good graphics card and single core performance is important for gaming.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Monitor
ASUS TUF Gaming VG27WQ
Headset
Sennheiser GSP670
Well I dont care that much for upgradability since I'm looking at this as a long term investment. Taking that into consideration, which one would be a better choice?
5 minutes ago, 8lec said:
Also, avoid Dell.
Yea that's basically baked into my subconscious for the past 5-6 years now. But their laptops used to be pretty sweet around 2 years ago when I bought mine.
It kind of is but from the looks of it, I wont be able to get that since 11th gen and 5000 series is crazy expensive in my country. I made the choice of the 10700 when I compared it to the 5600x which are basically the same price but the 10700's 8 cores give me leeway for some intense workflows while still giving basically the same performance of the 5600x in productivity.
I prefer Ryzen cuz it's more efficient and a little bit faster in games. If you use CUDA in Blender, the you could also go with a 5600x and the 3070.
You have to see which programs you use and how different configs will affect your work/play
  • CPU
    i3-6100
  • Motherboard
    Gigabyte H110m ds2
  • RAM
  • GPU
    1660 super
  • Storage
  • PSU
    Corsair CX750
  • Audio
  • Operating System
    Windows 10 (1907)
