Search In
  • More options...
Find results that contain...
Find results in...
1070 wont get more than 24 mh/s on eth
hi, my 1070 aero itx wont go higher than 24 mh/s even with a memory overclock, is there anyone that knows how to fix this.
Seems fine for that card.
Is it plugged in? Is it turned on? Are you sure? No, really.
ive read websites that say it should be able to get 30/31 mh/s
Alright, how big is your mem OC - talking 2% or 15%?
its 0, every time i overclock the memory nothing changes in the hashrate
No I mean by how much do you oc the memory? How many MHz?
i could get it to +600 without crashes
Hoooooly-
wow. That’s a lot for mem oc. Try OCing the core, it may be bottlenecking the memory.
Hoooooly-
ill try, should i lower the power limit with it?
No, maybe even raise it.
okay, i will
On Pascal core clock matters quite a bit as well when mining ETH, so OC that as well.
44 minutes ago, Mel0nMan said:
Hoooooly-
They can go quite high, but it's only "stable" in the sense that it doesn't crash. Pascal has ECC memory, so your effective performance will start to go down again at some point because it encounters more errors that need correcting. +1000 can easily be stable, but give worse performance.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | Storage: 250 GB Crucial BX100 SSD + 2 TB Seagate HDD + 1TB WD Green + 3TB WD Red | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
what do you think is the sweetspot?
Will depend a little on your card and how efficient you want to be. I usually open GPU-Z and tweak stuff until Memory Controller Load is as close to 100% as I can get it. Sometimes, for some reason, that means underclocking memory, sometimes I can go all out. My 1080 Ti is typically at +200 core / +500 mem and 75% power target.
the memory controller load is already at 100% so thats probs why i cant tweak it
You can still tweak it, just try to keep it there while monitoring hashrate and checking if that goes up.
please do NOT raise power limit for mining, and please do NOT advice people to raise power limit for mining workload
the reason you may be getting lower hash rate than ideal (online calculators):
1) you have a display connected to it, thus taking up some bandwidth
2) power limit too low (only if you set it quite low already, it never requires past 100%, in my experience, most GPU would be around 60% or so, only exception is 3080 and 3090 which requires them to be 80-90%, depending on models)
My PCs: Desky | Beddie | Miney | Benchie
Things I need help with: (nothing at the moment)
none atm
I hate Intel's pricing, Ryzen's weird quirks, Nvidia's pricing, and Radeon GPUs in general
Products I like:
Sony Xperia Z1 / Z2 / 10 ii, Asus Strix 970 / 1070, Samsung SSD, WD HDD, Corsair PSUs (AX, RM, CX(grey)), GeForce GPU, NZXT N450/S340, be quiet! Coolers, G.Skill Trident RAM, Logitech M525, Logitech G440, Razer Deathadder Elite
Products I hate:
Xperia Z3, XiaoMi 5c, Radeon GPUs, Razer Audio Products, any bloatwares
Companies I absolutely adore: (and hope it stays that way)
be quiet! - sent me AM4 mounting for my DRP3 even though it's way past the timeframe stated, no questions asked
Corsair - very good RMA experience, absolutely recommend
Companies I hate:
Nvidia, Intel, Apple, TMT (Thundermatch, a retailer)
Personal Blacklisted Companies:
Acer: shit tier quality products, shit tier customer service thus far, they "tried" to solve my issue but they arent really doing anything but delaying and delaying. (on-going case since July)
Gigabyte: horrible customer service (gigabyte had literally 0 customer service, asked me to go to retailer with NO WAY to email them about a question) but at least they fixed my shit in ONE MONTH (would probably take me 1 hour to fix if they let me email them)
XiaoMi Phones: built like a tank but the software is buggy as all hell
Seagate HDD: had too many dead seagate drives
Kingston SSD: 300V controller swap thingy
Razer (except their mouse)
Remember, just because I had good/bad experiences with these companies/product, doesn't mean you will have similar experiences too. I would still recommend these products if they made sense for your needs, but I'll add a disclaimer of my experience if it's relevant. Feel free to DM me asking why they are where they are.
While troubleshooting my PC after loop maintenance I ran on the iGPU for 2 days. I did not expect such a difference in hashrate. of my 1080 Ti. On good days I'd get like 34-36 MH/s with the right settings, but without anything attached and it doing literally nothing else it had no problem reaching its former glory of 42 MH/s. Same for Ravencoin, which went from 20 to 24.
Sounds about right
My hashrate can go from 58 to 43 while scrolling LTT forum
none atm
Products I like:
Products I hate:
Companies I hate:
i just checked this thread again after a week of mining with the power limit raised, does this affect the lifespan of the gpu?
Can't say for sure, theoretically it should be fine though
But it's always good to pay it super safe especially when gpu are hard to come by
none atm
Products I like:
Products I hate:
Companies I hate:
okay, ive lowered the power usage again and didnt lose any hashrate so im guessing it never used those 12% extra power it could use
It most definitely used it but it doesn't help with mining except using more power and producing more heat
none atm
Products I like:
Products I hate:
Companies I hate:
that could be yes, the temps dropped about 2 degrees
