Being able to embed clips (both yt and twitch)
Solved by colonel_mortis,
Twitch has removed the embed API, so we can't automatically embed them.
YouTube's embed API doesn't work properly. We have some special casing for it, but the dedicated URLs for clips and shorts are new enough that the special casing for them isn't included in the version of the forum software that we're currently using. At least one of them will be supported in the next update, but I don't have a timeline for that. URLs that are /watch?v= should work properly though.
