Problems with ultrawide 2560*1080 on windows 10 with hdmi to dvi cable
to the horizon
So my current setup is a LG 34WK500-P monitor and a windows 10 PC with AMD Radeon R5 340X. I am connecting the monitor with an hdmi to DVI cable and the computer just not able to register the monitor as a widescreen and only allow me to select 1920*1080. I tried updating drivers and nothing seems to work.
One thing is that I used the same monitor and same PC and same cable but with a Linux system and it worked. So I am not sure why it doesn't work after I convert the OS from linux to windows.
DVI (single-link, aka HDMI) is limited to 1920x1200@60fps maximum. You may be able to drop to 50 or 30fps to increase bandwidth.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
That is what I found online, but I was confused since I seems to get it work when my machine is running linux. Let me try to get a cable first and see if it works.
Only DVI has this limit; HDMI supports higher single-link speeds. Most graphics cards support sending HDMI compliant signals through their DVI ports, so higher resolutions can work using a DVI to HDMI adapter as long as the DVI is on the graphics card side.
This is most likely a software restriction in the Windows AMD driver. Try installing the AMD pixel clock patcher and restarting your computer.
