Search In
  • More options...
Find results that contain...
Find results in...
Will a 1440p 144hz monitor look like a 4k monitor when it is run at 1440p?
i currently checked at 4k 60hz monitor. or it will look better than that
Quote
Depends. Resolution that high doesnt matter if youre talking below 32 inches, 1440p would still be "retina" to you in a normal viewing distance. Refresh rates will affect your viewing more in a computer monitor.
Remember to press quote to get a response from someone! | Check people's edited comments! Press F5 to do so! | Remember to press that check mark on the right answer that solve your problem! | React to your heart, not peer pressure!
"Wow, you want me to say ara ara? Really?"
- Clock Girl
Self Introduction and Current Rig
🏳️‍⚧️ Rights
27inch 1440p and 4k diff is rather small but noticeable, 4k monitor ran at 1440p will look blurry, as with anything not at native. I think definitively i'd rather have 144hz than 4k 60
5950x 1.32v 5.05 4.55 82C 185w (still testing, likely not stable) R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-28-2T (zen doesn't like timings as much) 1.49v 45C 1.15v soc ll evga 1080ti hybrid (waiting on next gen) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 185w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5450 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-32-280-24 ddr3733  bdie 1.49v 45C 1.22sa/1.18 io  ll EVGA 2080 ti XC 1995//7600 325w 69C stock voltage (bad ocer) ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
A higher refresh rate will give a better viewing experience, but what matters to see the difference in 1440p and 4K monitor quality (pixels) is the screen size.
On a 24 inch monitor for example, it's hard to see difference between the resolutions. If it's 32 inch, 4K will surely look sharper. Some people say that on 32 inch 1080p monitors, you can almost count the pixels.  If it would be only 20 inch (or less), then you can hardly tell the difference between 1080p and 1440p, let alone 4K.
yeah i was also meaning the native resolution. will 144hz look better on games or genreal usage also btw none of the videos are 144fps like youtube.
Yes, the jump from 60 to 144Hz is much more noticeable than 1440p to 4K in games.
Current Specs:
CPU: AMD Ryzen 5 5600X - Motherboard: ASUS ROG Strix B550-E - GPU: PNY RTX 3080 XLR8 Epic-X - RAM: 4x8GB (32GB) G.Skill TridentZ RGB 3600MHz CL16 - PSU: Corsair RMx (2018) 850W - Storage: 500 GB Corsair MP600 (Boot) + 2 TB Sabrent Rocket Q (Storage) - Cooling: EK, HW Labs & Alphacool custom loop - Case: Lian-Li PC O11 Dynamic - Fans: 6x Noctua NF-A12x25 - AMP/DAC: FiiO K5 Pro - OS: Windows 11 preview - Monitor: ASUS ROG Swift PG35VQ - Mouse: Logitech G Pro + Powerplay - Keyboard: Logitech G915 TKL - Headphones: Beyerdynamic Amiron Home - Microphone: Antlion ModMic
Temperatures @steady state: Furmark + CinebenchR23 running for 1 hour. Fans @850RPM. Pump @1600RPM.
Water: 37°C
CPU: 73°C
GPU: 54°C
