Search In
  • More options...
Find results that contain...
Find results in...
Does a lower temperature mean I can further lower voltage?
Go to solution Solved by Levent,
Nope. Lower temperatures does not mean you can run lower voltages.
My CPU is already undervolted, and this was mainly done due to my terrible quality thermal paste. An all-core load gets me to around 80c. I know that more heat means more resistance, but does this mean that an already lower temperature would allow further undevolting? I'm not asking for advice about how I should replace my thermal paste, I know I should, and I will, but I'm just curious. Like, if my CPU right now at 80c can be stable at 1.28v, would there be a chance of stability at 1.26 if I had a better cooler? Sorry if it's a stupid question, but it sounds plausible enough in my head that it might be worth asking
mY s YsTeM iS Not pErfoRmInG aS gOOd As I sAW oN yOuTuBe. WhA t IS a GoOd FaN CuRVe??!!? wHat aRe tEh GoOd OvERclok SeTTinGS FoR My CaRd??
 HoW CaN I foRcE my GpU to uSe 1o0%? BuT WiLL i HaVE Bo0tllEnEcKs? RyZEN dOeS NoT peRfORm BetTer wItH HiGhER sPEED RaM!!dId i WiN teH SiLiCON LotTerrYyOu ShoUlD dEsHrOuD uR GPUmy SYstEm iS UNDerPerforMiNg iN WarzONEcan mY Pc Run WiNdOwS 11 ?woUld BaKInG MY GRaPHics card fIX it?
 MultimETeR TeSTiNG!! aMd'S GpU DrIvErS aRe as goOD aS NviDia's
