My DIY ASUS 14-1 Pin TPM-M R2.0 Module
I needed this. So I designed one. Hope it helps some of you.
Â
Parts
SLB9665TT20 TPM Chip:
https://www.ebay.com/itm/313526673758 -
2 mm pitch double row right angle pin header
Choose the 2x7 option
https://www.aliexpress.com/item/32887332295.html - 4x 100nF 6.3V 0603 SMD capacitors
- 2x 10K Ohm 0603 SMD resistors
PCB:Â
https://oshpark.com/shared_projects/pVqwq0NS -
3D Printed Shell
- Print with the outside facing upwards
- Suggested layer height: 0.16mm.
- Suggested line width: 0.35mm.
- Uses two 6mm M2 screw and nut.
Note: You do NOT have to follow the links I used. The specs are pretty laid out so you can source your own parts if you prefer.
Â
Assembly
You have to know how to solder VERY well. Experience in soldering TSSOP and SMD components is required.
Note the pin header should be keyed. You can cut a piece of the compatible pin and stuff it into the hole on the bottom row, the 3rd one from the right.
Note: if you are an amateur on soldering, this might not be a bad project to learn how to solder, since everything is quite affordable. Learn how to pre-tin SMD pads for caps and resistor, how to tack a chip in place, and then drag solder alone one side, then the other. We all have to start from somewhere.
Â
Installation
Jam it onto your motherboard with power turned OFF (I don't have to teach you the basics, right?) For my motherboard, once booted into the BIOS, the chip is automatically recognized and ready to go. Windows 10 also recognized it without any fuss.
Â
Updating Firmware
The firmware version on the chip might be quite out-dated and requires an update to work properly with Windows. Please check out the following guide on how to update the firmware on your TPM chip:
https://qzhou.dev/updating-a-vulnerable-tpm
Â
Note: It is possible that your chips might come with a rare firmware version and no update could be found. You might have to find a different seller and try your luck if that's the case.
Reference
Project Github Page:
Â
SLB9665TT20 Datasheet:Â
https://www.infineon.com/dgdl/Infineon-data-sheet-SLB9665_2.0_Rev1.2-DS-v01_02-EN.pdf?fileId=5546d462689a790c016929d1d3054feb
Â
Â
Â
Some photos of the thing.
Â
Â
