I need help upgrading my gpu (im a newbie)
Solved by Foxxx,
6 hours ago, jaslion said:You just unplug both gpu's?
NEVER mix cables between psu's UNLESS THEY ARE 1000% compatible.
I don't get why you would take the cables with the card. Your current 1070 is plugged in with at least a 8 and 6 pin. Just plug the 8pin into the 3070. However if it's the 3070 founders all you need to do is use the adapter cable and plug the 8 pin in there.
For the other pc just grab 2 6+2 pin cables or if you have separate 8 and 6 pin pcie power cables use those and plug them into the cards.
Thank you
