Do 6-32 screw flat work for wd blue hdd
Solved by mariushm,
yeah, regular 6-32 case screws can be used.
Floppy drives and optical drives use the slightly smaller m3 screws (metric standard - 6-32 are UNC 6-32 imperial standard)
Flat probably means shape of the head ... like this :
and maybe this kind also works :
Maybe they don't want the standard HEX shape because the height of the head could interfere with something in the case construction but I doubt it.
Just don't use the normal length ones, don't use very long screws.
