KVM switch with DP and 240hz
sauceyo
Heyy, I'm looking for a KVM switch for a single monitor (and min 2 usbs) with displayport in/out and support for 240hz (I have a Alienware AW2518HF 25")
I've been browsing on amazon but everything I saw said 4k60-30hz but no specifications for max refresh rate on 1080p
The first DP input will be from my PC on an RTX 3070, second one will be my macbook (which ill have to use a DP -> USBC cable for)
https://connectpro.com/product/udp-12ap-kit-2-port-usb-displayport-kvm-switch/?v=7516fd43adaa
You're going to pay a pretty penny for that.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
25 minutes ago, sauceyo said:
RIP thats a lot for just a KVM, is it just the fact that it supports 240hz that makes it expensive?
Pretty much I suppose. High refresh rate KVMs (and even 1440p/4k ones if I'm honest) are a bit of niche market. It's only recently have more and more people been seeking out for such a product. Your bog standard KVM like the Trendnet one I'm using costs like 20 maybe 30 bucks. Which is why I typically recommend people to just use their monitor to handle input switching and a cheap KVM to handle your mouse and keyboard. Many monitors can also handle audio output via DP or HDMI too so that's one less thing to worry about if you're using speakers.
  • 2 years later...
I understand that this was posted years ago when the 5K240hz gaming monitors were hard to find with unstable in quality (of cause listed more than USD $3000).
Finally, 2 weeks ago during the Cyber Monday, both  Samsung and LG had put the 5K240hz monitors into special discounts (lower than $760).  So I got a change to get one
o many users asked to unbox and test setup with external KVM switch that can support this very popular gaming monitor (the one of the best selling 5K1440P 49inch monitors for the Cyber Monday, 2023).
We got the monitor (LG 49GR850DC) (on 12/11).
After we got it, we have to upgrade and refresh the GPU driver/firmware installed on the gaming PC connected to make sure the GPU support DP1.4 DSC protocol.
The testing result was very well. We can proof that the advanced DDM 1.4 KVM switches DO support 5K1440P 240hz gaming monitor and 5K1440p 60hz Dell Ultrasharp U4924DW monitor sharing AT THE SAME TIME.
The unbox and testing link is on Reddit posted :
