CableMod PRO cable extensions for Corsair RMx 850W (2021)
27 minutes ago, kistomi01 said:But if I do a full replacement then Corsair's own cables should be fine right?
The Corsair-branded "full replacement" cables come with inline capacitors.
https://www.corsair.com/us/en/Categories/Products/Accessories-%7C-Parts/PC-Components/Power-Supplies/Premium-Individually-Sleeved-PSU-Cables-Pro-Kit-Type-4-Gen-4/p/CP-8920222
These capacitors are pretty much useless, make cables more fragile, more difficult to handle, and add failure points.
Corsair uses them with their stock cables (= the ones that come with the PSU) to top the ripple-suppression charts in reviews (that's really just marketing, you don't need ridiculously low ripple).
And to provide equivalent ripple-suppression with their individually sleeved cables, they implement them here as well.
You are better off with CableMods cables.
