Help for mini itx case
GinoSmoove
Because of space constraints I would like to get a SFF case. The issue is, I have a thick 3 slot 2080ti and I know not many mini itx cases would fit that. With prices being really high for cards I would like to not have to buy a new one if possible. I really like the Evolv Shift but I don’t think my card would fit unfortunately. Do you guys have any recommendations for cases I should check out? Bonus points if a regular size power supply can fit into it but definitely not required. :)
1 hour ago, GinoSmoove said:
Evolv Shift
I have this case. Had to buy one with better air flow as the machine ran hot. Would suggest getting one with better air flow. Maybe check out fractal design, they have some good cases.
==moved to cases==
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
