Search In
  • More options...
Find results that contain...
Find results in...
little problems about POP! os
Go to solution Solved by Sauron,
4 minutes ago, ke_luo said:
i can't type my passwords in the terminal when i do some sudo command(can't do it with hardware keybord and software keybord)
you can't see the password as you type it, this is by design. just type the right password and hit enter, it will work.
(can't create new folder,the disk set read only)
You need to install the ntfs-3g driver to mount an ntfs drive without it being read only. You should also check that the target folder is owned by your user and has write access, you can do this with
ls -la <folder path>
5 minutes ago, ke_luo said:
how can i use windows apps which in my disk already,like Genshin Impact,Plutonium T6/IW5
You can't without some sort of compatibility layer like wine, even then there's no guarantee.
i watch the video which about linux(link:https://www.bilibili.com/video/BV17U4y1H7w1 release in 2021/7/29),and i install my windows system in HDD and now i wanna rush into Linux without losing any data
and here's some problem
1:i can't type my passwords in the terminal when i do some sudo command(can't do it with hardware keybord and software keybord)
2:i can't create a steam library folderimage.png.db78202b359990adb957dcb6294d98e3.png(can't create new folder,the disk set read only)and i can't even use the steamlibrary folder i already have
3: how can i use windows apps which in my disk already,like Genshin Impact,Plutonium T6/IW5
sorry for  the error in the sentence,my first language is CHS,not EN (QwQ)
sudo chmod -R 000 /*
What is scaling and how does it work? Asus PB287Q unboxing! Console alternatives :D Watch Netflix with Kodi on Arch Linux Sharing folders over the internet using SSH Beginner's Guide To LTT (by iamdarkyoshi)
Sauron'stm Product Scores:
Just a list of my personal scores for some products, in no particular order, with brief comments. I just got the idea to do them so they aren't many for now :)
Don't take these as complete reviews or final truths - they are just my personal impressions on products I may or may not have used, summed up in a couple of sentences and a rough score. All scores take into account the unit's price and time of release, heavily so, therefore don't expect absolute performance to be reflected here.
-Lenovo Thinkpad X220 - [8/10]
A durable and reliable machine that is relatively lightweight, has all the hardware it needs to never feel sluggish and has a great IPS matte screen. Downsides are mostly due to its age, most notably the screen resolution of 1366x768 and usb 2.0 ports.
-Apple Macbook (2015) - [Garbage -/10]
From my perspective, this product has no redeeming factors given its price and the competition. It is underpowered, overpriced, impractical due to its single port and is made redundant even by Apple's own iPad pro line.
-OnePlus X - [7/10]
A good phone for the price. It does everything I (and most people) need without being sluggish and has no particularly bad flaws. The lack of recent software updates and relatively barebones feature kit (most notably the lack of 5GHz wifi, biometric sensors and backlight for the capacitive buttons) prevent it from being exceptional.
-Microsoft Surface Book 2 - [Garbage - -/10]
Overpriced and rushed, offers nothing notable compared to the competition, doesn't come with an adequate charger despite the premium price. Worse than the Macbook for not even offering the small plus sides of having macOS. Buy a Razer Blade if you want high performance in a (relatively) light package.
-Intel Core i7 2600/k - [9/10]
Quite possibly Intel's best product launch ever. It had all the bleeding edge features of the time, it came with a very significant performance improvement over its predecessor and it had a soldered heatspreader, allowing for efficient cooling and great overclocking. Even the "locked" version could be overclocked through the multiplier within (quite reasonable) limits.
-Apple iPad Pro - [5/10]
A pretty good product, sunk by its price (plus the extra cost of the physical keyboard and the pencil). Buy it if you don't mind the Apple tax and are looking for a very light office machine with an excellent digitizer. Particularly good for rich students. Bad for cheap tinkerers like myself.
okay......but i don't understand how to do it,just install the wine and click the .exe file?
and ,thank you for the help (OvO)
wine is hard to configure, most people use an interface like PlayOnLinux.
-OnePlus X - [7/10]
If you're looking to try some games from the Epic Games Store, you may want to try https://github.com/Heroic-Games-Launcher/HeroicGamesLauncher
This lets you use Proton for Epic games without any extra configuration. Not sure if Genshin will work as they may have some anti-cheat that won't let it work in Linux, but most offline or non-multiplayer games should work fine.
