Triple Monitor Setup Help
gperson2
Hi all,
I already have a 49" super ultrawide monitor and I would like to add two 27" monitors, one on either side, and game with the image extended across all three. My GPU is an RTX 3090. My present understanding is that Nvidia Surround won't let me do this because the monitor resolutions are different (the ultrawide is 5120x1440 and each 27" is 2560x1440). Is there a way to make this happen, either through Nvidia surround or another way? Thanks!
what are you trying to do? create a 360* degree screen and for simulators or something? using fullscreen applications?
10 minutes ago, gperson2 said:
Hi all,
Is it not possible to create a custom reselution in Nvidia kontrollpanel?
Sure it's possible but as far as I can tell I cannot test a resolution bigger than what my ultrawide will display on its own.
Okey if that not works i don't know and i'm not home and could look it up on My PC either Good lucka to find the problem
Mostly for driving simulators but for as many games as I could get to work. I don't have a use case for other sorts of applications, other than having many Edge windows and documents viewable simultaneously, but I don't need Surround for that.
Not sure for Nvidia surround, with AMD card I used AMD Eyefinity for my 3440x1440 and two 2560x1440 monitors and it worked, and although UW has different brand and resolution, freesync still works for all 3 monitors
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
Unfortunately it appears that while AMD does indeed support combining monitors with different resolutions, the Nvidia solution does not. Should’ve gone full team red this time I guess.
On 8/4/2021 at 12:15 PM, Quackers101 said:
I have used Nvidia with different resolutions, not what you are doing though.
How did you do it?
1 hour ago, gperson2 said:
How did you do it?
works automaticly, sort of.
Also have g-sync on one of them if that matters and using 1080 card.
although some windows 10 problems with the edge between the 2 resolutions is not always perfect unless in fullscreen.
Edited by Quackers101
  • 2 years later...
Hi everyone! Wondering if there is an update in regards to utilizing nvidia to merge 3 different resolutions monitor. Im currently gaming on a Samsung G9 5120x1440 240hz and added one 27inch monitor on each side (1920x1080) 165hz. Am I supposed to go team red and it will work?
