Static pressure fans VS Airflow fans.
Solved by narrdarr,
static pressure fans are designed to move air through or around objects. such as radiators, filters,hdd cages,and more.
airflow focused fans are designed to move a larger volume of air. which is great if theres no obstructions.
back in the day you kinda had to choose. now days any decent fan are fairly well balanced between noise, static pressure, and airflow
fyi the fans you've chosen are not that good.
the stock fans are better. and if you want a solid cheap fans to replace or add. just get some arctic p12/p14 argb
