1 input 3 output physical selector (don't know if it's possible)
Solved by Freakwise,
Yeah, Those are basically a simple switch there's literally no electronic inside it irrc, and I don't see reason why it would cause a signal degradation,
26 minutes ago, Makaida said:also don't know if this would be compatible with an AMP? Or if there are options out there which already include an AMP.
Amp as in normal amplifier?
You could connect it between the headphones and the switcher
28 minutes ago, Makaida said:I'd also like to keep my motherboard's microphone entrance free as I'd like to have an external mic (not a headset one).
Well, the mic in and stereo out is different port, unless you mean something else?
