Upgrade Advice.. is it worth it?
Hi everyone 🙂
Contemplating an upgrade but wish to know whether it is worth it.
Currently have a 8700k, 32Gb 3000mhz RAM & a 3080 FE.
Looking at a Ryzen 5600x with an update to 3600mhz RAM.
It is worth the upgrade? I don't do any productivity, only gaming. Will I see a tangible difference at all?
Many thanks,
Louis
If it were any GPU other than a 3080, I would say no. However, since it is a 3080, you are likely to be a bit CPU bound. Monitor your CPU and GPU usage in games, and if you're GPU drops below 95% usage for more than a second here and there, then you probably should upgrade to a 5600X. Also, you might as well just keep the memory and try to overclock it a little bit to get it to 3200MHz+. If you didn't have memory, yeah get 3600MHz, but since you do, might as well see if you can get it up to within the sweet spot of Ryzen.
depends on you
only if you're CPU limited in games, which highly depends on many factor such as what game, what resolution, what FPS etc etc
-sigh- feeling like I'm being too negative lately
The 8700K is still a very capable gaming chip. Unless you're gaming at 1080p or using medium-low settings, you probably won't notice a difference, even with a 3080. I'd keep saving up for a more substantial upgrade like a 5900X, or wait on a future CPU, or invest in a better monitor if that's at all lacking.
I try most titles 🙂 I have a 32" 1440p 144hz Display. Doom Eternal is lush at Ultra Nightmare settings.
A lot of titles i see the GPU pegged and CPU never at 100%. Most of the time between 40 - 60% with the exception being Flight Sim.
Thanks for your inputs!
Might as well stay with my 8700k then for a bit 🙂
Money saved LOL
