Search In
  • More options...
Find results that contain...
Find results in...
Will it give out 144hz and survive for the next 3 to 5 years?
Budget (including currency): 1050 USD or 78,000 INR
Country: India
Games, programs or workloads that it will be used for: Fortnite, Forza Horizon 4/5, Rocket League, Trackmania and Trackmania Turbo
Other details: Will be able to use a 240GB SATA SSD from my old one.
Parts that i have chosen:
AMD Ryzen 7 3700X
16GB Crucial RGB RAM
Antec DF600FLUX Case
MSI B450M MORTAR MAX
GTX 1650 Ti 4GB
Any 700w+ PSU
is the above one good?
else suggest some good ones.
My Requirements
6+cores and atleast 12 threads
16GB RAM
At least 500gb NVMe
4GB of GPU
Motherboard with 2 PCle slots.
Seems decent. But I would recommend also buying a 2 or 4 tb hdd for games, as 240gb is not a lopt of space. Just Fortnite and Rocket League (with all of the extra content) are around 60 gb so that's something to keep in mind. All of those games combined would take up more than half of your 240gb SSD so another larger drive would help.
Is it plugged in? Is it turned on? Are you sure? No, really.
The parts you chose are good, but some advice though. First off you don't need a 700+W PSU for that. You're fine with 550W or 650W surely.
Then the GPU, the GTX 1650 Ti is not available, it's only for laptops. Do you mean the 1650 (Super) or 1660 Ti?
Also, your title says 144hz for the next 3-5 years. In all games you mentioned you can easily get 144hz, except Forza Horizon 4/5. That's a bit of a demanding game and needs more graphics power to run at 144hz constantly.
For the SSD, use your 240gb one as your OS drive or buy a new 500GB NVME as your OS drive, then buy a 2TB or bigger HDD for your games. 500GB is not enough for all the games you mentioned.
No HDDs, i want to with all SSD kind of build, yeah i will use the 240GB for the OS, and another NVMe for games (1TB but not sure which one )
700W + coz i may add another GPU mayber RTX when price gets low, also it makes it kind of future proof. I'm not sure....
Its decent, but the CPU bias is not what i would go for.
PCPartPicker Part List
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor  ($150.99 @ Adorama)
CPU Cooler: FSP Group Windale 6 60 CFM CPU Cooler  ($49.99 @ Amazon)
Motherboard: Gigabyte B560M DS3H Micro ATX LGA1200 Motherboard  ($109.99 @ Newegg)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($87.99 @ Adorama)
Storage: PNY XLR8 CS3030 1 TB M.2-2280 NVME Solid State Drive  ($119.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 3060 Ti 8 GB Founders Edition Video Card  ($399.99 @ Best Buy)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($59.99 @ Amazon)
Power Supply: Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply  ($72.39 @ Amazon)
Total: $1051.32
Generated by PCPartPicker 2021-08-01 09:08 EDT-0400
Remember to press quote to get a response from someone! | Check people's edited comments! Press F5 to do so! | Remember to press that check mark on the right answer that solve your problem! | React to your heart, not peer pressure!
"Wow, you want me to say ara ara? Really?"
- Clock Girl
Self Introduction and Current Rig
🏳️‍⚧️ Rights
Okay, so you want no HDDs. Then get a 1TB m.2 NVME for sure. I recommend the Kingston A2000, WD SN550, Samsung 980 or Samsung 970 Evo (or Evo Plus)
Then get a 750W unit, you will be fine for RTX cards (except the 3090. My recommendations are Corsair RM750x or MSI MPG A750GF.
Total: $1051.32
I'm sorry, but some parts you chose are not good. Also, I wish we could get a RTX 3060 Ti for $400.
I don't suggest that FSP cooler, they are average quality. The SSD is fine, but for the price you can get better ones.
Also, the PSU is a big no. It's old and outdated and doesn't work fine with new GPUs. The risk is too big with that unit, they often break too.
35 minutes ago, thenlan said:
theres almost no reason to get zen 2 now, unless you find it really cheap, either a 5600x, 10400f, 10600k, 10700f (250usd),11400f is probably cheaper, but it depends on local pricing, i'd only do it for deep sales/clearance, throw any money you save on the cpu/psu onto a better gpu.
 be sure to check ur local pricing for other cpus.
5950x 1.32v 5.05 4.55 82C 185w (still testing, likely not stable) R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-28-2T (zen doesn't like timings as much) 1.49v 45C 1.15v soc ll evga 1080ti hybrid (waiting on next gen) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 185w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5450 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-32-280-24 ddr3733  bdie 1.49v 45C 1.22sa/1.18 io  ll EVGA 2080 ti XC 1995//7600 325w 69C stock voltage (bad ocer) ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
Very hypocritical of you to say that while recommending the RM series. But yes, seasonic Asus is a good alt too, with newer Focus-esque design.
Its bound to go down. Lets be real.
SN550? P2? Both a DRAMless nvme SSD, and its not like 3030s are all horse arse from the switcheroo PNY is playing. But if you think the switcheroo gives you bad taste, then that 2 i just name drop is a good alt too.
212 Evo is also average quality, an almost 10 year old bad design thats still being made to this day.
- Clock Girl
🏳️‍⚧️ Rights
Actually I'm in India so RTX is like extinct here, as far i have checked stock won't come till half of 2022
Hell yeah, would definitely consider this, got me with the RTX!
If RTX is not possible should i go for 1080 Ti or 1650 Ti both 4GB?
Will consider those upon availability, thnx
Chances are if rtx is still not available or scalped then there's high chance both of those gpu experience the same thing...
BRUH...
1080 Ti is not comparable to the 1650 Ti at all. The 1080 Ti is or was a high end card with 11GB VRAM. It's still kind of expensive nowadays ($1000 back in the day).
About the PSU, it's true both are not comparable to each other. Actually Asus PSUs are not good at all, unless it's not the ROG Strix series. Only the Thor series are good. ROG Strix PSUs use the same Seasonic Focus Plus platform too, which is NOT good for RTX 3000 cards.
Yes, it will go down eventually.
I'm recommending him budget NVME SSDs, best bang for the buck. The PNY you mentioned is actually better. If he wants a good one, he should get like a 970 Evo (Plus).
212 Evo is average too, but somehow still used frequently. Best air cooler (but also expensive) would be a Noctua cooler. I assume he wants something with RGB maybe though.
Should i go with 550w psu?
but i'm talkin about the 1080Ti 4GB version
75,000 INR approx = 1050 USD FYI
Pre Built ones are cheaper by like 270 USD
Should i still build one
  • 2 weeks later...
You made a mistake there. It's the GTX 1050 Ti 4GB. The GTX 1080 Ti is 11GB and maybe 5 times more expensive and powerful.
*pics*
1. Nice build with the Ryzen 3600, the rest are standard components. B450 board is already older by now.
2. Not suggesting the i5 build
3. Ryzen 3600 is good. That seems a nice balance, but try to get 1650 Super is possible, it's also better than 1050 Ti. Same for #1. B550 board is good.
4. It's not worth paying extra for the 3600XT. X570 board is better than B550, but you might not need that.
5. Good, but Ryzen 7 is too much just for gaming
6. I won't suggest the i7 there
7. Good, but Ryzen 7 is too much just for gaming
Try to get a Ryzen 3600, B550/X570 board, 16GB RAM, GTX 1650 Super or maybe even GTX 1660 (Super/Ti), any SSD, Bronze PSU, any case, cooler is up to you (stock or aftermarket).
Just pay more for Ryzen 7 if you really need it.
yup, was looking for ryzen7 as i would not change the processor for the next 4+ years
oh yeah 1050ti only, 1650 Ti is there but am not sure about the Super version. Will check
