What do I need in my motherboard/case to be able to install Phanteks RGB Strips and turn on RGB fans?
Josh -_-
Hi so I'm looking at buying the Phanteks Neon Strips in my PC that i'm going to build https://www.pccasegear.com/products/48072/phanteks-neon-digital-rgb-led-kit But I don't know if you need a particular case that's compatible or a particular motherboard that is ARGB or RGB compatible.
Here is my build of my motherboard and CPU. https://au.pcpartpicker.com/user/Josh1982/saved/#view=4PnRK8
I haven't decided on a case because I want one that could possible support RGB bypassing the motherboard, the cases i'm looking at are, but im also open to suggestions.
https://au.pcpartpicker.com/product/ybH8TW/lian-li-lancool-ii-mesh-atx-mid-tower-case-lancool-ii-mesh-performance
https://au.pcpartpicker.com/product/bCYQzy/corsair-4000d-airflow-atx-mid-tower-case-cc-9011200-ww
https://au.pcpartpicker.com/product/3RJmP6/phanteks-eclipse-p400a-atx-mid-tower-case-ph-ec400atg_bk
https://au.pcpartpicker.com/product/YCH8TW/lian-li-lancool-215-atx-mid-tower-case-lancool-215-black
Thanks.
To use ARGB devices you need an ARGB controller. The motherboard you have there is the controller you need, cuz it has  ARGB headers (Addressable LED Header)
so you are fine. Remember that Drgb or digita-RGB is the words manufacturers that didn't get the memo use, for ARGB 😄
FYI phanteks neon uses JST 3 pin connector
u probably will need a adapter cable to convert it to mobo ARGB ones
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer pin out guide +  other useful videos - Cases and Mods - Linus Tech Tips
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
Where could I find an adaptor?
The combo that was linked in the original post says it comes with that cable.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
  Hide contents
Oh cool so it comes with it.
