USB C hub questions
One thing to keep in mind is the sort of USB Type C the docking station requires.
USB Type C is a physical connector, but with many sorts of protocols behind it, such as USB 2.0, USB 3.2 Gen 1 (USB 3.0/5Gb/s), Thunderbolt 3, etc.
A lot of USB Type C docks will require the USB Type C to be a certain speed, but may also require it to have something called 'DP Alt Mode', or "Displayport Alternative Mode", which means it can share video signals over the USB Type C port.
This is something already relatively uncommon on many laptops, but on PC it's even more rare.
There are of course motherboards that have this function, but usually those are the more luxurious motherboards, those with Thunderbolt.
A USB Type A ('regular USB') docking station has its own (pretty underpowered) graphics chip in it, good for just displaying an image (such as for Office work and stuff), but it's not powerful enough for more intensive workloads (think playing 1080p60fps/4K video, gaming, etc.).
When using a dock, you of course would want to use the power of your graphics card. A laptop with USB Type C including DP Alt Mode can do this, by transferring the video through that port.
With desktop motherboards, the only way I've seen them do this, is by having a motherboard with Type C Thunderbolt and then it has a "Displayport In" port, to allow the graphics card to sort of transfer its video stream to the motherboard, which then it goes to the Type C port and then your dock.
Example:
ASUS' upcoming Crosshair VIII Extreme motherboard. Note the two USB Type C ports, with the thunderbolt symbol next to it. It also has a "DP IN 1" port, which is the port that allows your to connect your graphics card, so the USB Type C/Thunderbolt ports can actually transfer video signals from it.
TL;DR: So it is possible to do, but requires some compatibility between your motherboard and the hub in question.
