Recommendations for RJ45 Connectors Compatible with 28 AWG
Solved by Falcon1986,
8 hours ago, oblivion-npc said:Has anyone dealt with terminating these super slim ethernet cables before?
Can't say that I've dealt with slim cables before. For in-wall runs, I tend to go with regular sized cable to ensure I maximize the insulation and reduce possibility of interference. For short runs, I'll get patch cables of appropriate length that are pre-crimped.
