my first Itx build and i need help!
Solved by wONKEyeYEs,
16 minutes ago, Timedemon2000 said:lc power 1530mi or the silverstone vt01
Those cases are so small they don't have room for a PSU.
You need to buy an external power brick.
If you don't absolutely need something that small it would be more convenient to get an itx case that takes a SFX PSU.
nate c ·
Posted in General Discussion1 -
ulookuglynoob ·
Posted in Peripherals0 -
23
2
cheersalt1 ·
Posted in Cases and Mods0
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
