Im currently using storage spaces on windows and im trying to move over to a real Storage solution need help.
3 minutes ago, SomethingUnique22 said:Sorry replying to everyone i have to repeat a few times.
yaaa i suppose your right.
I have heard of them i was always worried of not having enough PCIE lanes tho. I tried to figure out the current lanes i use with my gpu and wifi/bluetooth card plus my sata drives and i got very confused and gave up.
Also wouldnt it have slower speeds then compared to using regular sata ports on the mobo?
1 minute ago, Electronics Wizardy said:Won't affect performance. HDDs are slow, so they aren't even close to filling sata or the pcie 1x connection.
This. Also, OP, this is why a HBA is the best option. HBA's are SAS cards, SAS is high performance and you can split a single SAS port out into 4 SATA ports. Enterprise solutions use SAS... Don't worry about slow downs, if there are any, it won't be due to the HBA.
Just need to flash it to IT mode which is not difficult, plenty of guides online show you how. But if you don't feel comfortable with that (which is fair) folks sell them already flashed to IT mode for like 50-60 bucks. This will last you forever, will not be flaky, and will grow with you when you eventually get a more robust solution like unRAID or FreeNAS. This is one of the cards of choice for FreeNAS. Just NEEDS to be in IT mode.
